Dear Sir,
Is it supported by TWL5030 to direct analog microphone uplink data to both Voice PCM I/F and Audio I/F, simultaneously?
Typical use case will be, normal voice call with Modem thru Voice PCM (8KHz) I/F, and recording uplink data (44.1KHz) thru Audio I/F by OMAP.
If possible, what/how registers configurations are required on top of voice call configuration?
Thank you.
Logan
