Dear all:
I have some confuse on the current setting of LP8556 with I2C function, Let me double confirm below questions:
The <25mA/ch is optimized in TI factory, if customer want to change the Maximal current, they can set register in EPROM through I2C(it need IC support I2C master), Is it correct?
Now I suggest customer to use LM8556-E02, it support I2C master, if my understand is correct, customer can set the Maximal current to 50mA/ch in EPROM and use I2C to do the dimming. Do you agree?
thanks!
