We are planning to use LM46002 as non inverting converter.It will generate +24V to -24V/1A supply for our system.when i read through the data sheet i found that it has Hiccup mode. But in our application some times the load will vary (12A High peak current will occurs) Did the PGOOD Pin can help in this situation??
Can we use this IC for our application??
