TLC59116-Q1 / tlc5927-q1
Other Parts Discussed in Thread: TLC5927-Q1, TLC59116-Q1
Dear Sir,
May I confirm the specification of this two part TLC59116-Q1 / tlc5927-q1?
1.TLC59116-Q1:
Can it be adjusted  the  current gain of each Individual channel ?
How to control the LED Brightness? by LED pulse cycle ? or current?
2. tlc5927-q1:
    For the TLC59116-Q1, you can change the PWM duty cycle to change the brightness of each individual channel. This will also change the average current.
    For the TLC5927-Q1, you would also have to use PWM duty cycle to change the brightness of each individual channel.
    The difference is that the TLC59116-Q1 allows you to change a register for the duty cycle. The TLC5927-Q1 will do it manually using the shift register.
