Hi Sir
May I know bq24610 datasheet page 24 Figure 17. Vreg What is the voltage?
is VREGN_REG REGN regulator voltage 6V?
Hi Sir
Hi Wang,
In Figure 17, Vreg is the voltage you charge your battery up to. You can usually set this value by changing the resistor divider at the Vfb pin. The equation for is:
Vreg = 2.1(1+ Rtop/Rbottom)
Where Rtop is the resistor from Vbat to Vfb, and Rbottom is the resistor from Vfb to ground. We usually recommend keeping Rbottom at 100k Ohm, and adjusting Rtop to get the correct regulation voltage.
For your second question, you are correct. REGN is an integrated LDO set to regulate at 6V.
