UCC2800 Error Amp across temp range
Hi There,
The Error amp ratings are taken acorss the full temp range for the part (-40C to 85C). However I was keen to understand if there is further data provided on the performance at room temp (25C). I appreciate the change is +/- 1uA for full range, but this was asked by my customer.
Many thanks,
Ross
  • Hello Ross,
    TI generally does not provide that information and guarantees data sheet parameters over temperature per the data sheet specifications.
    If TI was to give that information customers may think they could design to tighter tolerances versus the worse case specifications.
    Mike
