Hi Team,
I am working with the BQ20Z45-R1 where it never goes into Sleep mode even after sending the ManufacturerAccess Sleep command.
After digging into this issue, I found that changing the Wake Current Reg to 0 makes the BQ20Z45-R1 go into Sleep mode. Have you seen this behavior before?
A couple notes:
- The battery is non removable so NR bit is set to 1
- Sleep current is 10mA. Changing this to higher value does not help.
If you need a to look at the schematic setup, I can send it to you offline.
Thank you,
Jared
