Dear Sir,
I have a question about ground pad.
If the board and IC ground pad don't contact very well. Is it will cause any risk?(like thermal, Vout accuracy)
Thanks for your help!
-Ben
Hi Ben,
yes there are risks:
Description from datasheet, page 4: Exposed Thermal Pad: Must be connected to AGND (pin 6), PGND (pin 15,16) and common ground plane. See the Layout Example. Must be soldered to achieve appropriate power dissipation and mechanical reliability.
Best regards
Lubomir Fenic
