Hi
I have some question from customer about the following configuration.
Vin pin is connected to Vout after startup. (Vin pin is connected power supply rail (= real Vin line) when it startup.)
Do you have any concerns about the above configuration?
I wonder the CSx pin operation affects if the Vin pin is high voltage (e.g. 11V) and real Vin line is lower voltage (e.g 3V).
Koji Hamamoto
