Hi all
Would you mind if we ask bq25890?
What is IBAT(LOAD)(Battery discharge load current 15mA) used for?
On REG03, is it possible to switch on/off?
Kind regards,
Hirotaka Matsumoto
Hi all
Kind regards,
Hirotaka Matsumoto
Jeff san
Thank you for your reply always.
We'd like to confirm one point.
The internal battery load (IBATLOAD) can be used with the internal ADC in order to determine if the battery is present.
->Otherwise, unless IBATLOAD is set enable, it not sure that BAT pin connects to battery, right?
Kind regards,
Hirotaka Matsumoto
