BQ40Z60 SOH how often is it updated
Other Parts Discussed in Thread: BQ40Z60
Hi Team,
I'm looking at the BQ40Z60's SOH feature.  Can you provide some info/insight into how often and when this parameter is updated? I noted that in a system I am working with that this value not only needed the correct values for the battery design capacity, but appeared also need to go through a rest and recharge cycle.  Can you elaborate on the process the device needs to execute to result in the correct values for SOH?
thanks,
Steve
