Regarding TPS6102x (more specifically TPS61029), I would like to confirm that if this pin gets externally pulled down by other circuits, the booster circuit can still operate normally, i.e. pulling down LBO pin will not affect internal operation of TPS6102x while it is in regulating, or starting up, or from power down to power up.
From datasheet, LBO is an open-drain pin without any connection to internal circuit of TPS6102x, so I suppose there will not be any impact from LBO pin to the booster. Please help confirm. Thank you!
