Hi Team,
The BQ21040 disables charging at <=0C per the TS section of the datasheet. However, the recommended min operating temp for the IC is 0C. Can you please confirm that charge will predictably remain disabled at temps down to -40C and resume at >0C? This is what is described on the TS section, but need confirmation since it is outside the recommended temp range.
Any characterization data, if available, would be very helpful.
Antonio
