BQ33100 Questions
Guru 11170 points
Other Parts Discussed in Thread: BQ33100
Hi all,
Please let me know about BQ33100-EVM and GUI.
[1]
In datasheet, 2-pin is "Not used and must be connected to VCC", However in EVM schematic, 2-pin is opened.
Which is the correct?
[2]
If this device to use for 5-cells, is 13-pin to opened?
[3]
On table 81, default number is 0x04a8, but I read out 0x0208 from explanatory text of registor.
Is default number(bit) shift to left?
[4]
When set to 0x0208 at "OperationalCFG", indicated 4-voltages on GUI window.
Please let me know how to setting for 3-capacitors.
[5]
I found a sentence of "Capacitor Voltage Balancing is only operational after the ManufacturerAccess Lifetime and Capacitor Balancing Enable (0x21) command is sent to the bq33100.".
Please let me know how to send a command 0x21 from GUI to EVM.
Nagai
