Hi everyone,
We are using FDS8447 as a switching mosfet for the PMIC (BQ24616) . As per the theoretical calculation mentioned in the datasheets ,the Power dissipation of the Mosfet (Including Conduction and Switching Loss ) gives a temperature rise of about 5 deg cel from Ambient temperature . But the actual temperature read near the Switching Mosfets in PCB gives an rise of 22 deg cel which is contrary with the theoretical calculation.
Actual temperature is measured using an thermistor which gives an accuracy of +/-1 Deg cel and no inaccuracy of reading the temperature.
What could be reason for the change in theoretical and practical value of the switching mosfets power dissipation ??
Rajesh K
