Hi Team,
I am aware that the resistor on VC1 and VC2 are not the same in bq28z610 simplified Schematic. 100 ohm is on VC1 and the other is 5 ohm.
Could you kindly let me know the reason?
Hi Team,
Concerning bq28z610 and VC1. I am trying to interface to an existing battery pack with 2 Li-Ion 18650 in series. We do not have a feed from between the cells (VC1). Can I use this BQ28Z610 and what do I do with VC1?
Don
Unfortunately, you can't since you do not have a midpoint connection. The bq34z100-r1 will be a better fit for your application
thanks
Onyx
