I want to use a Buck regulator in my project, specifically TPS62740. I saw in its datasheet when we connect the Enable pin to ground the IC goes into the shutdown mode, and it also mentioned in the datasheet that when IC is in shutdown mode the Isd(shutdown current) is max 1000nA. I want to know one thing that what is the Output voltage of the IC when its in shutdown mode? and also is the Isd is equal to quiescent current in shutdown mode?
Thanks.
