Device tree entry for LP3943 in linux3.14
Other Parts Discussed in Thread: LP3943
Hi all,
I have some problems and need your help.
I use the LP3943 chip for LED control in linux3.14.
I need control the individual LED's brightness and blink.
In the Linux Device Tree Document, there are 3 files related to LP3943.
Documentation/devicetree/bindings/mfd/lp3943.txt
Documentation/devicetree/bindings/gpio/gpio-lp3943.txt
Documentation/devicetree/bindings/pwm/pwm-lp3943.txt
After enabling driver support, I refer the example of document for establishing device tree.
i2c_0: i2c@78b7000 { /* BLSP1 QUP2 */
                        pinctrl-0 = <&i2c_0_pins>;
                        pinctrl-1 = <&i2c_0_pins>;
                        pinctrl-names = "i2c_active", "i2c_sleep";
                        status = "ok";
                        lp3943@60 {
                                compatible = "ti,lp3943";
                                reg = <0x60>;
                                pwm3943: pwm {
                                        label = "LED0";
                                        compatible = "ti,lp3943-pwm";
                                        #pwm-cells = <2>;
                                        ti,pwm0 = <0 1 2 3 4 5 8 9 10 11>;
                                gpioex: gpio {
                                        compatible = "ti,lp3943-gpio";
                                        gpio-controller;
                                        #gpio-cells = <2>;
                leds {
                        compatible = "gpio-leds";
                        indicator1 {
                                label = "LED0";
                                gpios = <&gpioex 0 GPIO_ACTIVE_LOW>;
                        indicator2 {
                                label = "LED1";
                                gpios = <&gpioex 1 GPIO_ACTIVE_LOW>;
                        indicator3 {
                                label = "LED2";
                                gpios = <&gpioex 2 GPIO_ACTIVE_LOW>;
                pwmleds {
                        compatible = "pwm-leds";
                        rgb {
                                label = "PWM";
                                max-brightness = <255>;
                                pwms = <&pwm3943 0 10000>;
And I saw following entries in the /sys/class/leds/
root@OpenWrt:/sys/class/leds# ls
PWM
root@OpenWrt:/sys/class/pwm# ls
pwmchip0
Why the gpio-leds devices disappear?
GPIO and PWM of LP3943 can coexist or not?
If I want to control the individual LED's brightness and blink, how should I do?
Have any examples of device tree for LP3943?
Thanks you,
Kay
