Now I am texting the bq24616EVM refer to SLUU396A,but the BAT text point has no current output.
the power supply #1 is 24v.
load #1 I use 10Ω resister.
load #2 I use 6 cells batteries( the total voltage is 19.6V ).
what is wrong?
what is wrong?
Hi Winningbear,
The EVM was set up with the TS pin voltage divider expecting the thermistor from the battery. Without this, the charger will automatically go to TS fault. You can force 2V on the TS pin with a power supply to make the device work (or change the resistor divider).
