Could you tell me about IOCL calculation formula?
Customer wants to know how to calculate the IOCL to determine the rated current of the inductor.
TPS54425 ocp.pdf
Yusuke/Japan Disty
TPS54425 ocp.pdf
Yusuke/Japan Disty
Hi Yusuke-san,
The overcurrent protection for TPS54425 is implemented using a cycle by cycle current limit. The IOCL in the datasheet is the valley current limit level from ATE test. It is a low side current limit level not related to the working condition. It is not necessary to calculate the IOCL from OCP threshold. What you could do is to calculate the ripple current for inductor and add up the IOCL in the datasheet to get the estimate peak inductor current during OC.
For example, if the ripple current for inductor is 2A. Typical IOCL for TPS54425 is 5.4A. The estimated peak inductor current will be 7.4A under OC.
Anthony
Anthony-san,
Thank you for your support.
Let me ask you one more thing.
I found the following post.
https://e2e.ti.com/support/power_management/non-isolated_dcdc/f/196/p/539133/1968070#1968070
And I found the following formula from your post.
・OCL threshold = IL/Rdson
・Valley current level = Iocl-1/2*inductor ripple
Customers want to calculate the exact OCL value in accordance with the inductor.
Could you give me your advice?
Yusuke/Japan Disty
