We are observing an issue where the Full Charge Capacity (FCC) value will change shortly after a cell has discharged to it's termination voltage.
The following is a plot of several logged parameters. Note that our device turns off (stops drawing significant current where the Voltage begins to climb again).
Notice that the FCC abruptly changes from 563 mAh to 267 mAh.
Is the FCC expected to behave like this? I would have assumed that the learned FCC would not change - at least not until the BQ27421 relearns.
