Hi Team,
Do we have solution to support the AMOLED driver?
AMOLED spec required:
OLED power supply :OVDD 4.6 V
OLED power supply :OVSS -2.9V
driver IC source output power supply AVDD 7.6V
SHH
Hi Team,
SHH
Hello SHH,
Can you give more specific details about the AMOLED driver, such as the max. output current, the dynamic performance requirements or does the driver have any power up/down sequence requirements? If you like you can send me the datasheet.
Thank you.
best Regards.
Ilona
Hello SHH,
Thanks for sending the datasheet. In consideration of the power requirements I can recommend the TPS65632.
As this device can only generate 7.7 V for AVDD, I recommend to use an additional LDO to get the 7.6 V. This device has also two enable signal, where you can enable AVDD and OVDD/OVSS separately.
Let me know the feedback from the customer.
Thank you.
Best Regards.
Ilona
