So far as I know, the design equations are never included with reference designs, only schematic, BOM, and if applicable the PCB gerber files and test report. The PMP4992 is a special case usage of TPS40210. Normally it is intended as a boost controller. That is why you cannot find your design in Webench. It will only select TPS40210 for boost topology applications.
As it turns out, I know the designer of PMP4992 personally. Let me see if I can get him to answer your questions.
I'll ask if he might have them. Otherwise you may need to reverse engineer it.
