Part Number: BQ20Z95
In my system if the Fast Charge Current (C431 in the TRM) is set higher than the first (C221) or second level safety current (, the battery doesn't charge. A TCA (terminate charge alarm) is set on the SMBUS. If the FCC is set lower, the operation is normal.
We receive the batteries from a battery manufacturer programmed with FCC set higher. I was hoping they knew what they were doing.
Should the first and second level safety current be set higher than the fast charge current?
