Hi E2E,
My customer is using the LM3429BKBSTEVAL with Rov2=332k and Rov1=5620 to achieve a voltage of about 74V and a hysteresis of 6.6V.
If the voltage rises above 74V, does the IC regulate the LED current to maintain 74V or does the IC shut down? Their tests show the IC trying to regulate the current to maintain the output voltage of 74V but the datasheet (pg 18) says the GATE pin is immediately pulled low. Which is it?
-Sam
