I have questions about TPS259231.
I connect a power supply of 5V to VIN terminal of TPS259231.
A different power supply (possible even if a battery) is connected to OUT terminal.
Please teach me the behavior when the power supply of the VIN terminal was cut off.
(1)
If FET was turned off, does the VIN terminal observe the voltage of the OUT terminal via the diode of the internal FET?
(2)
If (1) is "Yes", how much does the electric current flow?
Does the resistance value between the VIN ~ EN/UVLO terminal ~ GND determine it?
(3)
If (1) is "Yes", depending on the voltage observed at VIN, is EN/UVLO terminal recognized as High, and does the FET become ON again?
(4)
If (3) is "Yes", how does TPS259231 behave?
Dice-K
