I was calculating the minimum required ESR value for LM34919C-Q1. On page# 17 in datasheet, there's a formula to calculate the minimum resistor in series with output cap (R3(min) in datasheet). If we want to calculate R3(min) then IOR should be maximum but in the datasheet formula it is reversed.
Is this a typo error or this is the correct way to calculate series resistor?
