TLV733P: Need a Drop in Replacement for TLV733P
Part Number: TLV733P
We are using TLV733P on our board. But the problem with TLV733P is the maximum input voltage is 5.5. So i need a drop in replacement for TLV733P which has all specifications same as TLV733P but with higher input range. Also the replacement should be available with Fixed  output voltages of 2.5, 2.8,3.3.
  • Hi Kiran,
    In order to help you select the best linear regulator for your application, please provide some more information about your use case such as your intended Vin and output current. I see that you listed your Vouts already. Please also note that TLV733P comes in two packages.
    We provide a parametric search to help customers find the best LDO. I have filled in your stated requirements to give you a head start here.
    Very Respectfully,
    Ryan
