Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
LM22670: LM22670 variable Vout
Part Number: LM22670
Other Parts Discussed in Thread: LM10011, LM10010
Has anyone variably adjusted the Vout of the LM22670 using a programmable digital pot IC?
I was wondering if the high impedance indicated on the data sheet for the FB pin would prohibit the use of a digital pot to replace RFBB
    I think the high impedance on that pin is because of the input impedance of the error amplifier inside the IC. I would doubt that your digital potentiometer impedance is in that range. But in order to change output voltage normally we use LM10010 or LM10011
