TPS7B7702-Q1: Question of Fault Table
Part Number: TPS7B7702-Q1
Hi all,
Questions about Table 1. Fault Table of the DataSheet.
Please tell me the Fault table of 2ch LDO.
When one LDO becomes Short-circuit or current limit,is ERRB low?
Or is ERRB low when both LDO becomes Short-circuit or current limit?
Also, when LDOSWITCH OUTPUT is Disabled, is the output voltage going down even when EN = HIGH?
Similarly, what is the EERB output of "thermal shutdown", "battery short circuit output", "reverse current" and "LDO switch output"?
Koji Hayashi
  • Hi Koji-sann,
    /ERR will go low when one or both outputs hit current limit or short-circuit. Output voltage will go down even with EN=HIGH as soon as LDO switch output has been disabled by a fault condition such as thermal shutdown. For the /EER status, you can use datasheet TABLE 1 for reference. /EER will go low when you have thermal shutdown, output short to battery or reverse current on one or both outputs of the LDO.
    Jason
  • Hi Jason
    Thank you for your quick response.
     I understand.
    Koji Hayashi
