TPS767D301: TPS767D301
Part Number: TPS767D301
Is the powerpad on the TPS767D301 electrically connected to any other pin?  Should the powerpad be soldered to the ground plane connected to the device gnd? I currently have the powerpad connected to a chassis layer. I am measuring continuity, about 700 ohms,  between chassis and the device ground. I have no continuity on a pcb with no TPS767D301 installed.
