I don't plan on using the shutdown functionality or overcurrent functionality of this part. Can I just leave the ALERT pin floating or should I tie it to VSS?
if over-curent alert function is NOT used, the ALERT pin could be used for WAKEUP pin. If not, ALERT pin typically can be pulled up to the LDO.
Should I use a pullup resistor, or would it be okay to just tie it directly to 3V3?
