Other Parts Discussed in Thread: ADC16V130
I am using the power sequencer UCD90160 in my design. It has 3 analog ground pins (AVSS3, AVSS2, AVSS31) for the 16-bit ADC inside. The userguide mentions them as analog ground pins. This chip also has three digital ground pins (DVSS3, DVSS2, DVSS31).
From my experience, I have an understanding that these pins are named analog ground and digital ground due to the existence of separate physical grounds inside the IC. On the PCB board, they should be tied together to one single ground plane. Am I correct on this? I think the same has been told by TI employee Joshua Carnes while explaining the grounding required for one of the ADCs (ADC16V130).
I am sharing the url of that post:
In my board, all signal layers have tightly coupled continuous ground planes adjacent to them so that the signals and their return paths are clearly defined. I don't want to cut the ground plane (to create analog ground) and invite hordes of problems like unanticipated return path loops, potential EMI creation, etc.
Will I be correct to connect all the digital ground pins and analog ground pins to a single ground plane?
Warm Regards,
Binayak.
