LM3414HV: current leakage with driver is in Off state
Part Number: LM3414HV
I've successfully implemented a LM1434HV LED driver. However when the driver is in Off state the LED strings are slightly illuminated. Measured current is about 6uA (enough to slightly switch on them). How can avoid this issue? In other thread (with no TI answers) I've seen something like adding a 330k resistor in parallel with the LED strings. I have some doubts with this workaround. Above all, what happens with this resistance when driver switches to On state?
Could someone from TI clarify this?
Thanks in advace,
gaston
