Does the TPS54328 discharge output caps actively when EN goes Low or VIN reaches down to UVLO threshold?
If yes, how does TPS54328 do it? (Low-side FET turns off? or any other discharge circuit exist?)
Go
Go
Hi Go,
To double check, you could apply a voltage like 2V on SW pin and GND and measure the current. If there is several mA curernt, subtract the current thru fb resitor, it is the discharge circuit current. You could calculate the resistance of the discharge circuit in this way.
Anthony
