Hi all
There is a following explanation at the terminal functions table in the datasheet P7.
" Each pin has a 1-µA pullup resistor."
Please tell me the value of pull up resistor?
Sho
Hi Darwin-san,
My customer wants to put pull-down resistor at D1/D0 to be controlled by MCU and not to be input Hi-Z when power supply of MCU is off.
Could you tell me recommended value of the pull-down resistor?
Yaita
Hi Darwin-san,
Thank you for your reply.
I believe less than 700kΩ for pull-down resistor is required because VIL is 0.7V (min).
* 1uA (internal current source of Dx pin) x 700kΩ = 0.7V
Is my understanding correct?
I assumed TPS2115 has power supply in this case.
Yaita
