Hi Team,
My customer has a question about TPS3896A signal timing.
If Enable_N signal go high before Tpd(r) delay in SENSE_OUT_N, SENSE_OUT_N keep high or go low?
Thank you.
Jade
Hi Team,
Thank you.
Jade
Jade,
For TPS389xA versions, both SENSE and ENABLE have a capacitor-adjustable delay. The output asserts after this capacitor-adjustable delay when both SENSE and ENABLE inputs are good.
TPS3896A: Active low EN, Active low, push-pull OUTPUT
Driving /ENABLE high makes /SENSE_OUT go high, regardless of Vsense. With Vsense already above Vit+, driving /ENABLE low will make /SENSE_OUT go low after the capacitor-adjustable delay time.
So if for this device, if /ENABLE goes high, /SENSE_OUT will go high after td(OFF) = 200ns.
See Figure 3 for TPS3896A (don't use Figure 1 since this is for the wrong device)
I hope this answers your question! Let me know if you have any more questions. Thank you!
-Michael
