Dears,
LM5175 is a good wide input and output Buck-Boost converter, I want used it to design LED driver, because I found the HDRV2 pin product the PWM signal after the output voltage need to establied. If my load is LED that the output voltage can't first existence, so the HDRV2 pin is still no PWM signal and the mosfet will become so hot. Do you have a good method to solve it? Many thanks!
Best regards!
Jacking
