WEBENCH® Tools/UCC25600: Overcurrent operation
Part Number: UCC25600
Tool/software: WEBENCH® 디자인 툴
Hello ~
UCC25600 What is the overcurrent protection method?
I want to know whether it is limit mode or heat-up mode.
please answer about my question..
Thank you.
  • Hi Woo,
    Overcurrent protection uses a dedicated pin and will latch when triggered. It uses the voltage across the resonant capacitor which is proportional to the load current. The description is found in section 7.3.2 of the datasheet: www.ti.com/.../ucc25600.pdf
  • Brian Hello ~
    Thank you for your reply.
    I do not wanna be a latch on overcurrent protection.
    Is OCP a Hiccup Mode? Or Current Limit?
    During the test,
    On-off operation time of over current protection becomes faster and on-off operation is stopped at short time.
    (Current Limit)
    What OCP behavior is correct?
    Is it possible to keep on-off at regular intervals during over-current protection?
    I do not know if Google translates correctly ...
    please answer about my question...
    Thank you.
