I need a clarification regarding the "Average, positive input current limit" spec and the "Average, negative input current limit" of the TPS63070.
My interpretation is that positive input current limit is it is the maximum input current limit for the device (the normal peak current limit you would see in a typical power supply IC datasheet).
However, the "Average, negative input current limit" defines the maximum inductor current ripple the IC will tolerate (positive limit - negative limit).
Is this correct?
Chris Turner
