Hi, I am having questions about the LED pins on BQ78350-R1 IC.
The first question is if the LED pins are open drain or cmos? Then if the pins are not used, what should I do? Do I leave them there or I need to ground them? If I need to ground them, do I need to add resistor to each LED pin?
Thank you very much!
