I am using the Bq20z655-R1 in a battery pack 4S3P (14.8V - 10200 mAh) using the Sanyo Panasonic cells model NCR18650BF.
The EVSW was updated using the last chemistry updater.
The NCR18650BF chemical ID is 2142.
After programming and calibrating the pack, even leaving it resting for 5 hours, the FCC showed does not correspond to the actual value. It is showing FCC of 7979mAh. I have tested the pack (charging and discharging at C5) and, the actual capacity is 10170 mAh.
Please let me know how to correct this discrepancy.
Ronaldo
