Linux/LP8860-Q1: software configuration
Part Number: LP8860-Q1
Tool/software: Linux
I  debug the LP8860-Q1,but Internal registers are not configured successfully,and The official website don't have Configuration Guide,Can you help me to  Configuration register,thank you!!
    Could you give me a little more detail on the issue? I'm assuming you're not using GUI and EVM.
    Are you trying to configure LP8860 registers or EEPROM? If it is only registers then you can just write directly through I2C and register will be configured immediately but if you're trying to write EEPROM registers then you'll need to unlock EEPROM first and continue with EEPROM programming  sequence:
    Hope this helps,
    Salome
