To whom it may concern, I am using LM2587SX-ADJ/NOPB as a boost regulator to boost +24v to +48v, the design worked ok on 2 proto phases about 25 assys, yet I have had some outline failures, where the regulator just stop working, outputting +7v and not switching. The implementation of the design was taken from the datasheet application notes, there is no specific failure mode, only failure description is it was working and then it stopped. The application of this +48v regulated is to driver 2 strings of LED (RGB), the controlling to turn on the LEDs are separate, the regulators just provides +48v.
