TPS7A84: Question about the internal charge pump circuit
Genius 4220 points
Part Number: TPS7A84
My customer is concerned about the effect of TPS7A84/85/89 internal charge pump circuit on its input and output noise.
So I'd like to ask about the following things,
1. What is the switching frequency of  the TPS7A84/85/89 internal charge pump ?
2. Regarding the output noise voltage spec described in D/S, Does the spec take account of the effect of TPS7A84/85/89 internal charge pump circuit?
3. Is there any possibility that the input ripple voltage of TPS7A84/85/89 is increased by the effect of internal charge pump?
Go
  • HI Go-san,
    Let me answer your questions below:
    Please share your concerns about the Charge Pump noise.
    *Typically around 4MHZ.
    * The noise in the D/S is from 10 to 100KHz. The charge pump is running well outside this range.
    *I don't believe so as this is a very low current charge pump that is created just to control the gate of the pass element.
    Thank you,
