Hi~
On testing TLC59116 EVM, leakage looks higher than specsheet.
On spec sheet, SCL, SDA max lekage is 0.3uA, but when test EVM, it looks larger than this.
TLC59116-390 standby current@5V is 37.826mA, but when remove I2C pull up resistor(R1, R2), supply current reduced 37.302mA, so three I2C leakage is around 500uA(each has about 170uA).
Is this expected result? or can we reduce leakage on I2C or any other parts on TLC59116 circuit?
Thanks.
