Other Parts Discussed in Thread: TPS7A8300, TPS7A91
In the data sheet, the minimal recommended capacitor for SS is 100nF, which translates to about 8mSec startup time.
I need to get less than 1mSec startup, and it looks from the block diagram that using lower capacitance values ~10nF shouldn't be a problem,
apart from the fact that the startup time calculation will not be as precise..... Is that OK? If not - what is the lowest possible value of SS cap I can use?
Thanks!
