For TPS65950, audio block, please provide a example sequence of De-initialization and initialization, when we switch between different outputs(IHF, EARPIECE, HEADSET)
Audio(mono) is coming from pcm interface routed through audio L2 path.
Will there be any impact on the De-initialization and initialization sequence, depending on the Master/Slave mode of PCM interface.
Thank you
