BQ34Z100-G1: What does Suspend Low Temp and Suspend High Temp parameters do?
Part Number: BQ34Z100-G1
Hi. I am trying to understand what flags will be set in extreme temperature for battery pack.
I know that OTC and OTD flags are set if charge or discharge happens for particular time at particular temperature.
I know that CHG_INH flag is set if temperature is below or above particular temperature, and the flag is cleared only after temp is lower/higher depending on hysteresis.
But what about Suspend Low Temp and Suspend high temp? What flags are set and in what conditions? I could not find that in datasheet.
Karlis
