There is following picture on the datasheet p32.
Does it mean that the wake up event must be asserted after tstart(=3ms)?
Kuramochi
Kuramochi
Hi Kuramochi-san.
As Brian already indicated, when the ECU is coming up from fresh start (or input power cycling), device does not need wake input to power up. This is usually the case with ECU supply connected to KL-15/ignition supply (or non-permanent supply). If the ECU is supplied directly from KL-30/battery line (or permanent supply), ECU will see the power cycling only when battery is disconnected/connected from ECU (typically in the factory/repair center) and in this case, ECU is turned off (or LPM0 mode) through SPI control and reactivation of ECU is through rising edge on WAKE.
Hope this is clear to you now.
Murthy
